How to create a pie chart to show the percentage of issues for each request type?
dv bhadram September 2, 2023
How to show the request types related issues in a piechart.
2 accepted
Danut M _StonikByte_
Hi @dv bhadram,
You can use the Pie Chart dashboard gadget of Jira.
If you hover the mouse over the chart, it displays the percentage.
I hope this helps.
Danut.
dv bhadram September 3, 2023
Thank you for your valuable suggestion, but I asked for the request types.
You should be able to generate the chart by Request Type field as well. Did you try this?
Danut.
Like dv bhadram likes this
dv bhadram September 4, 2023
I couldn't find the request type option in Jira.
Isn't "Request type" a custom field in your Jira instance? If yes, what type does it have?
Please provide a screenshot with the custom field's definition and another one with the place where it is used.
Danut.
Have you added the Request Type field as a custom field in your Jira instance?
Tomislav Tobijas
As stated, Request Type, a.k.a. Customer Request Type field is a system field that cannot (yet) be used in gadgets:2023-09-04_13-09-03.png
You could create some custom field that is named Request Type and that stores some value based on Customer Request Type value (e.g. use automation to copy request type name/string into that custom field) which you could then use in your reports.
Like # people like this
Like Tomislav Tobijas likes this
Tomislav Tobijas
It's not currently possible to add Customer Request Type field on Pie Chart macro or Jira dashboard gadgets.
You can see a related question here: https://community.atlassian.com/t5/Jira-Service-Management/Is-it-possible-to-create-Pie-Chart-according-to-Request-Type-in/qaq-p/1087263
Also, here's a feature suggestion on the system dashboard: https://jira.atlassian.com/browse/JSDCLOUD-1914
I would suggest using some marketplace add-on (whether for Jira or Confluence) until this is implemented.
Best,
Tom
FREE
