How to disable the Draw.io Simple Viewer?
Edson Biancato Bagio March 19, 2025
After I enable the Draw.io Simple Viewer I can't find an option to disable it.
The documention only explains how to enable it. It mentions that the checkbox is used to enable and disable it, however, there is no mention of how to disable it.
https://www.drawio.com/doc/faq/confluence-cloud-viewer-settings
https://www.drawio.com/doc/faq/confluence-simple-viewer
Bagio
Cyrille Martin
Hi @Edson Bagio
To untick the "simple viewer", you need to edit the diagram. On the top right you can uncheck the option
Hi, @Cyrille Martin ,
Worked.
I hope Draw.io improves this UI. Unnecessary steps and complexity.
MJ Valencia -drawio diagrams-
Hi @Edson Bagio
Glad it was resolved and thanks for the feedback. We always appreciate users letting us know where we can improve. We're continuously working on making draw.io as intuitive and user-friendly as possible.
Best,
MJ
Like Edson Biancato Bagio likes this
Hi, @MJ Valencia -drawio diagrams- ,
If possible, a good way to capture feedback would be to have a Feedback button in the product, like Atlassian does.
Thank you! @Edson Bagio We also have a service desk and a feature request button in case they ever come in handy. https://drawio-app.com/support/
FREE
