I am using Jira Create Product Requirement template to serve as the PRD. This template has a requirements section. I added "Area of Application" and "Status" to this section, in hopes I could pull all PRDs, Requirement section to be displayed in a table so that if someone is looking for the requirements for a particular, "Area of Application" they could see all in one place. Currently you would have to open multiple PRDs to review each requirements.
Ex
Parent: My App - Product Requirements
Child: Project - Integrate with 3rd Party ACB1
Child: Project - Integrate with 3rd Party ABC2
Child: Project - Add ability to TBD
Parent: Requirements
Here I would like to take the Child pages "Requirements" section, display here with ablity to sort. So that if multiple projects touch multiple areas, all requirements can be found in this section all together.
@Ambers Can you share a screenshot of how you are putting the pages together? Are you using the Jira Macro?
