I would like to embed a chart from the following website:
the embed code is:
<div id="co2-widget-container"></div><script type="text/javascript" src="https://www.climatelevels.org/graphs/js/co2.php?theme=dark-unica&pid=2degreesinstitute"></script>
However, I can't get it to work. I did my research and found a few options:
I'm stuck and like to ask you for help. Do I miss something obvious here? I'm new to Confluence.
Thank you for your help.
Out of the box, with Confluence Cloud, you only choice is to take a screen cap of the chart on the source website (you can instert the HTML link below to recreate it.
There is a commercial plugin available for Cloud that looks like it would work: html-macro-for-confluence-cloud
Turns out I had to change the default settings of the plugin. it works! Thanks
Cool. Good to know that a plugin actually works. ;-) And know we know there is a working solution for Cloud.
Read more 📚Online forums and learning are now in one easy-to-use experience.
