×Do you know a way to embed a Figma frame into a confluence page as a simple picture?
Without interactive scaling and navigation.
But the picture should be automatically updated when changed in Figma...
Hi @PM ,
Welcome to Atlassian community.
I have never played with Epigma but the below discussion says it can be done using smart links. You might want to check out.
I hope above info helps. Have a good day.!
Srinath T
Thank you so much for the answer.
I tried all 4 modes of SL displaying.
The first two are just the text form of the link. The card mode shows a small plate with a description and Figma logo. But not the content of the frame.
The embedded mode really shows the Figma frame, but it allows to scale, and move the frame within the visible area. So, it's can't be used as an illustration.
So, my problem is not resolved for now.
