I am trying to write a short CSS script within a confluence email to remove an element. Specifically, the img.rendericon element, that erroneously shows an external hyperlink when navigating to an internal confluence link. This icon, while small, causes some serious headaches with email formatting. It tends to block text on the above lines, and cause the formatting to be skewed. Please please please, help me figure out a solution here. I have already contacted out internal Atlassian support team and they said we cannot globally turn off link decorations. If there is a way to edit them via an email body, that would be perfect. Thanks
Hi @Kevin Kott
You are probably best off looking at the Atlassian Marketplace for an app that can customize email notifications.
If you don't find anything or can't convince the powers that be to invest in an app, you can share the following url with your Atlassian Admin team.
https://confluence.atlassian.com/doc/customizing-email-templates-168001822.html
It is unsupported and will not survive an upgrade, but instructions exist for editing the email templates.
Read more 📚Online forums and learning are now in one easy-to-use experience.
