I am trying to integrate Confluence with MS Planner. And I couldn't find a solution. Any help is appreciated
Best Regards,
Aarij
Integration is a big topic. What do you want to achieve with the integration? Embed info, sync, etc?
Leo
I want to have an integration, where in a designated space/page a widget is displayed with planner view where all the functions are available and clickable. Like iframe where Planner is shown.
OK, I will investigate and share some options.
Thank you very much :)
Hi, were you able to find anything?
Look in the Marketplace. I'm sure they are multiple addons that will integrate the two.
Thanks for the advice. The only one I find when I search "Microsoft Planner" is the following:
On top of the page it is mentioned, that they don't provide support.
Can you share links to other addons that you mentioned earlier?
You will be better off asking this question in a Slack or Microsoft Planner forum.
Sorry I wanted to write Confluence ... Was looking for solutions for both tools and posted this on wrong forum. Do you happen to have a solution for confluence?
Best regards
Aarij
