How to keep HTML tags?
Luka Simon Thies
I am automatically updating a table on a confluence page using the REST API.
To make this process easier, I wrote a template and added tags to the individual cells.
<td data="TAG">
Updating the page works completely fine, but when I try to get the page again, all these data-tags are missing again.
Is there a way or setting, that I am missing here?
Sunny Ape
February 11, 2025 edited
Hello @Luka Simon Thies
Is there a way or setting that I am missing here?
This is a frequently asked question. In short, the answer is no.
When you submit HTML as content for a page, it is parsed by Confluence, then sanitised, and some HTML element attributes, like data, are stripped out.
This is because Confluence's internal storage format is not pure HTML, but a hybrid format Atlassian calls XHTML, and it doesn't support the entire set of HTML objects / elements.
Google 'Confluence XHTML page storage format' to learn all about it.
