How to keep Text and Link-Formating and define Table Column Widths?
Deborah Frommer
Hi all,
I currently use the Table Transformer to define the column size of an table.
With the query:
SELECT *,
FORMATWIKI("{cell:width=20%}" + 'Type'+ "{cell}") AS 'Type',
FORMATWIKI("{cell:width=20%}" + 'all'+ "{cell}") AS 'all',
FORMATWIKI("{cell:width=20%}" + 'Request'+ "{cell}") AS 'Request',
FORMATWIKI("{cell:width=20%}" + 'Requirement'+ "{cell}") AS 'Requirement',
FORMATWIKI("{cell:width=20%}" + 'Task'+ "{cell}") AS 'Task'
FROM T*
Unfortunately the text formatting (bold text) and Links (to Jira-Filter) and other thinks are gone.
Is there a possiblity to keep the content and only define the column width?
In Edit Mode:
And in the normal view: --> formatting is gone
Thanks for your help and best regards.
Deborah
Stiltsoft support
March 1, 2024 edited
Hi @Deborah Frommer ,
Please use commas instead of pluses in you SQL queries, they will help you to preserve initial cell formatting.
https://docs.stiltsoft.com/tfac/dc-server/advanced-table-cells-formatting-58426218.html#Advancedtablecellsformatting-Preservinginitialcellformatting
Deborah Frommer
Thanks for your help.
Like Stiltsoft support likes this
Help us plant more trees
