In confluence there are spaces added between lines:
How to remove these such that it appears as it does in most text editors:
Hi @Nathan Slager and welcome.
I'd argue that there ARE spaces between the lines in most text editors. Maybe there's a marketplace code block app with more customization options.
Let's turn this around. What's your use case? A table with code sample?
az extension remove --name ml
This side of specialized editors/characters (that give an appearance of a single vertical line) I've never came across an uninterrupted vertical line.
And I've been thru many (including those on mainframes in zOS :) )
Help us plant more trees
