Sign up Log in
How to perform mass jira-ticket-link to jira-ticket-macro transformation on the page?
Aleksey Bandurin August 21, 2018 edited
Hi guys
Could anyone help with this issue? Have a list of JIRA tickets (about 250) links in plain text. Copy-paste it to the Confluence page and expect that it will be automatically converted to JIRA-ticket-macro as it used to be with a single JIRA ticket link. But the transformation doesn't perform and I still have a list of links as it listed below on the Confluence page:
But I expect something like that:
Please share a solution with the issue, don't want to do a monkey job  :(
Sattesh M
September 19, 2018
Hello Aleksey,
Since the links are pasted as, well, links, and the Jira issues seen in the second screenshot have quite a bit of info in them, I'm not sure if there's an easy way to do the conversion.
If you don't mind viewing them in table form however, I believe we can use some text editor magic to do that.
I'm using Notepad++ on Windows.
  1. I first have a list of plain-text links.
  2. I then replaced all the text before the issue key with "key=".
  3. Next, I replaced the line breaks with OR and a space, like "OR ".
  4. Now, we select all of that and paste it into the Jira Issues macro.
  5. And that should be it.
I know that's not exactly how you wanted Aleksey, but do let me know if this helps.
Sattesh
Aleksey Bandurin September 28, 2018
Thank you, Sattesh, for this solution. This is partly not what I need, but it can come in handy if no other variant is found.
Upcoming Confluence Events
