I want to add multiple excerpts to a page that I am generating in Python and writing via the REST API. I am beginning to feel that this is another feature that has been removed from Confluence when the V2 editor was introduced.
I am writhing the following:
h2. ADC_OFFSET_I_REG
h3. Register Overview
{excerpt:hidden=false|name=ADC_OFFSET_I_REG|atlassian-macro-output-type=BLOCK}
|Title |address|description |reset|
|ADC_OFFSET_I_REG|0x116| |0x00|
h3. Bitfield Descriptions
*Description of settings in register ADC_OFFSET_I_REG*
||*Setting* ||*Bits* ||*Mode* ||*Description* ||*Reset* ||
|ADC_OFFSET_I|7-0|RW|Programmable ADC offset|0x00|
{excerpt}
The excerpt macro is being stripped from the page (or at least the V2 editor is not displaying it.
I hope that this can be done since the alternative is to create 300+ pages containing individual tables? Any help would be appreciated.
Through trial an error I managed to find the solution to my problem so I thought i would share it for the rest of the community.
To read the page in structured format I used the following API call:
temp = wws.get_page_by_id(2106916966, expand="body.storage")
print(temp['body']['storage']['value'])
To turn the above page into the correct format I used the following content (excerpt code highlighted in bold:
<ac:structured-macro ac:name="excerpt" ac:schema-version="1" data-layout="default"><ac:parameter ac:name="name">ADC_OFFSET_I_REG</ac:parameter><ac:rich-text-body>
<h2>ADC_OFFSET_I_REG</h2>
<h3>Register Overview</h3>
<table data-layout="default">
<colgroup>
<col style="width: 180.0px;" />
<col style="width: 100.0px;" />
<col style="width: 300.0px;" />
<col style="width: 120.0px;" />
</colgroup>
<tbody><tr><th><p>Title</p></th>
<th><p>address</p></th>
<th><p>description</p></th>
<th><p>reset</p></th></tr>
<tr><td><p>ADC_OFFSET_I_REG</p></td>
<td><p>0x116</p></td>
<td><p>Offset value for I register</p></td>
<td><p>0x00</p></td></tr></tbody>
</table>
<p><strong>Description of settings in register ADC_OFFSET_I_REG</strong></p>
<colgroup>
<col style="width: 147.0px;" />
<col style="width: 48.0px;" />
<col style="width: 108.0px;" />
<col style="width: 363.0px;" />
<col style="width: 60.0px;" />
</colgroup>
<tbody>
<tr><th><p><strong>Setting</strong></p></th>
<th><p><strong>Bits</strong></p></th>
<th><p><strong>Mode</strong></p></th>
<th><p><strong>Description</strong></p></th>
<th><p><strong>Reset</strong></p></th></tr><tr><td><p>ADC_OFFSET_I</p></td>
<td><p>7-0</p></td>
<td><p>RW</p></td>
<td><p>Programmable ADC offset</p></td>
</tr>
</tbody></table>
</ac:rich-text-body></ac:structured-macro><p />
Please use the below answer
Use the Python wrapper below for reference
https://atlassian-python-api.readthedocs.io/confluence.html
Let me know if you have any queries
Pramodh
So is it correct that you can only add the macro in storage format, not in Wiki format. I will have to recode everything to output storage format and try it again. How do I get the body of the page in storage format so I can see how to encode it?
Got it. Unfortunately I do not have enough information to get the page output in storage <xml?> format. What I get looks more like <html>:
<h2 id="ExcerptTestPage-ADC_OFFSET_I_REG">ADC_OFFSET_I_REG</h2>
<h3 id="ExcerptTestPage-RegisterOverview">Register Overview</h3>
<span class="conf-macro output-inline" data-hasbody="true" data-macro-name="excerpt" data-macro-id="9075f925-e326-477a-b974-a16e7263568f" data-layout="default" data-local-id="31287b1e-4b75-473a-800f-59b1a4069f75">
blah blah<p></p>
<p>blah di bla</p>
<div class="table-wrap">
<table data-layout="default" data-local-id="098aa3c8-5254-4bcb-bfc7-29d25d093801" class="confluenceTable">
<colgroup>
<col style="width: 170.0px;"/>
</colgroup>
<tbody>
<tr>
<td class="confluenceTd"><p>Title </p></td>
<td class="confluenceTd"><p>address</p></td>
<td class="confluenceTd"><p>description </p></td>
<p>reset</p></td>
</tr>
<tr>
<td class="confluenceTd"><p>ADC_OFFSET_I_REG</p></td>
<td class="confluenceTd"><p>0x116</p></td>
<td class="confluenceTd"><p> </p></td>
<td class="confluenceTd"><p>0x00</p></td>
</tr>
</tbody>
</table>
</div>
<h3 id="ExcerptTestPage-BitfieldDescriptions">Bitfield Descriptions</h3>
</p>
<table data-layout="default" data-local-id="eb74d975-024a-437d-9625-db702bb35bd1" class="confluenceTable">
<colgroup>
<col style="width: 136.0px;"/>
</colgroup>
<tbody>
<tr>
<th class="confluenceTh"><p><strong>Setting</strong> </p>
</th>
<th class="confluenceTh"><p><strong>Bits</strong> </p></th>
<th class="confluenceTh"><p><strong>Mode</strong> </p></th>
<th class="confluenceTh"><p><strong>Description</strong> </p></th>
<th class="confluenceTh"><p><strong>Reset</strong> </p>
</th>
</tr>
<tr>
<td class="confluenceTd"><p>ADC_OFFSET_I</p></td>
<td class="confluenceTd"><p>7-0</p></td>
<td class="confluenceTd"><p>RW</p></td>
<td class="confluenceTd"><p>Programmable ADC offset</p></td>
</tr>
</tbody>
</table>
</div>
<table data-layout="default" data-local-id="37ff912a-4aea-4fd2-a047-4c16dbc7ec57" class="confluenceTable">
<colgroup>
</colgroup>
<tbody>
<tr>
<th class="confluenceTh"><p><strong>Setting</strong> </p></th>
</th><th class="confluenceTh"><p><strong>Reset</strong> </p>
</th>
</tr>
<tr>
<p>0x00</p></td>
</tr>
</tbody>
</table>
</div>
<p />
</span>
Hi Luca,
I did solve this. I had to recode all of my creation scripts to generate Confluence storage format which is a strange proprietary format. I then created 2 functions to start and end the excerpt.
def start_excerpt(self, name):
"""Start an excerpt on a Confluence page
End Excerpt using the end_excerpt method
assert not self.excerpt_active, "Cannot nest Excerpts"
self.excerpt_active = True
self.wr('<ac:structured-macro ac:name="excerpt" ac:schema-version="1" data-layout="default">')
self.wr('<ac:parameter ac:name="name">' + name + '</ac:parameter>')
self.wr('<ac:rich-text-body>')
def end_excerpt(self):
"""Finish the prviously started excerpt
assert self.excerpt_active, "No active Excerpt to close"
self.wr("</ac:rich-text-body></ac:structured-macro>")
self.excerpt_active = False
where self.wr simply writes to a text file opened elsewhere in the class.
Help us plant more trees
