Hello!
I have added an Add-on (please see the picture).
But, still I can't find a way to start using it. It is not in the list:
Hello @ruslans.klimovs,
Happy to help you begin using your Mind Maps add-on. I had a look at the vendor's documentation, and it appears that Mind Maps are a macro that you add on a page:
See Adding a Mind Map to a Confluence Page.
Therefore, there won't be a Mind Map template that you're looking for. You just need to create a new page, or edit an existing one, and add the macro using the instructions above.
Let me know if you have any questions about that.
Shannon
Thank you very much Shannon! I ve got the same answer from vendor!
It is really work!
Hi @ruslans.klimovs,
That's great! Happy to hear it's working for you.
Take care, and have a pleasant rest of your week.
Shannon
