×Requirements for static websites?
Hi Akash,
One question: is Confluence must-have?
Maybe you should use another CMS like Wordpress, Typo3 or something else..
For WP there are a thousands of Templates you can use for Prallax design - even for free.
Hope this helps.
Cheers, Mario
That's a good question, it's likely that Confluence is not a good fit for this
I have one more query, using confluence can i make a wiki page which can be accessible all over world without login panel on the front page.
Yes, make sure it's accessible over the internet and you've enabled "anonymous" access. You'll have the option for logging in in the menu at the top right, but the page will be displayed to all visitors without any login.
