Images appear different in edit mode vs in view mode
Ohad Oliver May 11, 2020
Don't know If it is a bug but i really need to find a solution for this one:
Images in edit mode appear different than in view mode.
In view mode they are much smaller, it is like all changes I make have no influence at all.
Adding a screenshots: 1st one is the view mode (after publish), 2nd one is edit mode
2.
Grigory Salnikov
May 12, 2020
Hi @Ohad Oliver and welcome to our Community!
Just to clarify, it's the one big image or several smaller ones?
Do you use just basic layout or have you tried to add sections and columns?
Thanks in advance.
Ohad Oliver May 12, 2020
The three big ones are the way it appears in editor mode, The 6 tiny ones are the way it appears in view mode. All 6 pictures are in both modes it's just that the window wasn't large enough for the screenshot to contain them all in editor mode.
Did that answer the question?
I have the "Two Columns" layout.
Pritesh Gohil
Try to use {section} and {column} macro. This might help you to arrange figure comfortably.
@Pritesh Gohil Using the new editor, sadly
