Is it possible to bring basic calculations in Confluence without making use of add on applications?
Nivedita
Is it possible to bring basic calculations in Confluence without making use of add on applications / plug ins?
 I want to create my own global template (in excel format) that needs basic sum, multiplication , division calculations.
Is this possible without purchasing any plug in / applications?
Andrey Khaneev _StiltSoft_
July 30, 2019
User macros are not available in Confluence Cloud, so it is not possible to create anything in this way. As previously mentioned, there are apps that can make table calculations, here is one more: Table Filter and Charts. It has these macros for calculation:
Kiran Panduga {Appfire}
Hi @Nivedita ,
Basically, this can be achieved through using User Macro inserting some sort of Javascripts.
If you are looking for add-on then you can try Advanced Tables for Confluence  or  CelesteCS Math for Confluence
Kiran.
