We have moved from the Server to the Cloud version of Confluence and Jira, and I have found that the default column widths of the table displayed via the Jira issues macro is too narrow. Can column widths be controlled and how?
One of the issues with Cloud, is you are very restricted when it comes to custimizations. Items that would be easy to fix/control with custom CSS, with or without a wrapper macro, just are impossible in Cloud.
And third-pary apps like issue-macro-from-jira-to-confluence arent avaible on the cloud.
So you only two options are to live with it, or learn how to develope Cloud apps: connect-frameworks-and-tools
Hi @John Steele ,
You may try our app - Table Filter and Charts for Confluence.
Its Table Transformer macro allows you to set the column width for manually created and macro generated tables (including the Jira Issues macro).
