Is it possible to integrate SharePoint with Confluence?
M B December 20, 2023
At one time I believe there was a plug-in, so I’m unsure if this is still available.
Connecting SharePoint with at Ryan Confluence is not possible then. Is there a chart that can be created in Confluence? They can show velocity and can be updated without requiring updates from different groups or teams?
Nic Brough -Adaptavist-
December 20, 2023
Yes, you can "integrate", but you need to start by defining what you want from the "integration" - it's a mostly useless word because it doesn't tell us anything beyond "I think I want two systems to talk to each other about something"
Confluence is not a charting or tracking tool, it's a wiki.  (Sharepoint is not a tracking tool either, it's core is a document store.  Although it's been bodged to become a backend for "Teams" as well)  It does not have the fields or data points that you would draw out most charts from, especially velocity.  Velocity tracking should be done in your issue tracker, not a documentation tool.
But Confluence does have lots of functions for drawing in and displaying data from other systems.  The most obvious (and best supported) option is to use Jira to track your issues, and then use the Confluence's Jira macros to draw in the data there, or embed Jira dashboard gadgets in pages.
@Nic Brough -Adaptavist- totally fair – I felt provide requirements, and was very vague. By integration, I mean SharePoint (Office) Lists, with which are synced to forms and forms submissions;  I have consistently and repeatedly recommended Jira however, I have been overruled  as others think JIRA is only for software lifecycle management. C if there is a macro or plug-in, or way to achieve some of these functionalities, that would be great to be able to deliver to the state quarters that wished to use on the confluence; if he best method and path of least resistance That would be great to definitively discern. Thank you for your help and guidance
Laurie Sciutti
December 20, 2023
@Laurie Sciutti thank you so much – I will check it out!
Like Laurie Sciutti likes this
Ilina Kabra
September 9, 2024
Hello! Yes it is definitely possible to integrate SharePoint with Confluence. Try GPT for Confluence and Sharepoint from Enterprise Bot! It uses ChatGPT to ingest all your existing knowledge from multiple platforms such as Confluence and SharePoint and builds a chatbot that can quickly find and deliver relevant information. It's pretty neat because it keeps learning over time without needing constant updates from you. You can integrate this kind of tool with Slack, Teams, or your internal Wiki to make sure everyone in your company has easy access to the information they need. It’s a smooth way to get accurate answers and make your search engine more intuitive. https://www.enterprisebot.ai/solutions/knowledge-management Hope this helps and happy to answer any questions!
FREE
