We use Confluence pages as homepages or workspace pages, with each team member using a personal space for some things, and each team using a full Space for their work/workflows. In each of those instances, we are often required to create Jira issues. Currently in order to do that, we have to navigate FIRST to Jira, where we only then find a Create button for creating an issue.
I'm looking to skip the entire step required to navigate TO and INTO Jira first, and have a button that just starts the Create-Issue event.
Does anyone know of a way to get this done? It would save us a bunch of time.
@Chris Purser You can follow the steps below to create an issue. https://support.atlassian.com/confluence-cloud/docs/use-jira-and-confluence-together/
You can create issues while viewing a page or from the within the editor, letting you use Confluence for planning and gathering requirements.
To create an issue when viewing a page:
Highlight some text on your page and choose the Create Jira issue icon that appears above the highlighted text.
Enter your server (if you have multiple Jira sites connected to Confluence), project, issue type and descriptionYour highlighted text will populate the issue summary automatically.
Select Create
The issue will be created in Jira and added to your page. If your text is in a table, you'll have the option to create multiple issues using text from the same column.
If you don't see a popup when you highlight text, check that Text Select is enabled in your profile settings.
To create an issue in the editor:
In the editor choose Insert > Jira Issue > Create new issue
Enter your server (if you have multiple Jira sites connected to Confluence), project, issue type, summary, and description
Select Insert
There are some limitations when creating Jira issues from Confluence. The Jira Issues macro or Create Jira Issue dialog will notify you if it's unable to create an issue in the selected project. You can find out more in the Jira Issues Macro page.
ok - Thanks Brant.
That's what I thought. There's no button macro option.
I added "SELECT SOME WORD HERE TO MAKE A JIRA ISSUE" to our homepages so now there is a way to do it.
These aren't 'planning' pages. These are starting pages - places where members start every day, with buttons/links to all the dashboards and 3rd parties they need to access for their daily routine(s). So the pages very rarely change. I was hoping for a button, but this is a reasonable hack.
Cheers.
@Chris Purser looking for the same. I don't know why this is not an OOTB option.
@Chris Purser and @Jonathan Bohlmann
I too am looking for the same feature. I assume this still isn't easily configured.
i am also looking for this option. Is there a ticket open about this?
