Is there a way to Group Whiteboard items?
David Shulman
Is there a way to group the items on a whiteboard?  For example we want to create a custom card with additional text (in the corners) that is linked to other cards via lines. When we move the card, the text doesn't also move unless you multi-select. It would be helpful if we could group visual items, so that moving the "card" would also move the text that sits on top of it.
Mark Skipper
August 20, 2025
This is basically a +1. I need this all the time: I want to create a re-usable graphic and copy, paste and move it about without having to select all the elements. Sections are not what I'm looking for here because they put a border around the items, the whole idea is that the items have a particular shape.
David Exner
@David Shulman , have you tried creating a section, adding desired items on it, and locking them there (right-click on an item -> Lock)? Then, you should be able to move them all at once by dragging the section itself.
Raffaele D’Elia
Items within a section do not need to be locked to move together with the section; they will move with the section regardless.
Locking objects prevents them from being edited (for example, you can't edit the text of a sticky note if it is locked) and also prevents them from being moved. However, you can still move the containing section if there is one.
I look forward to seeing a grouping feature added to Confluence Whiteboards.
Like # people like this
