Is there a way to create a simple list which users may view and add suggestions?
Irenio Calmon-Huang
September 15, 2022
The previous equivalent of this was the old tasklist macro:
Tasklist Macro - Confluence 3.5 - Atlassian Documentation
* Being able to add to a list without having to enter edit mode.
* Allows for simple deletion or re-arranging of entries.
Nice to have:
* Timestamp each entry
* Credits it to the submitter.
Alex Koxaras -Relational-
Hi @Irenio Calmon-Huang and welcome to the community
Confluence cloud has already this functionality, but not with the same layout as the showcased example. You can do the following
  • Add an action items on page
  • Use the @ to assign it to a user
  • Create a new Page and add the Template Task Report
  • Adjust its properties accordingly
  • Final result
Hope all the above helps!
Irenio Calmon-Huang
September 21, 2022
'allos Alex, thanks for the reply.
Really I'm hoping to find something that is much simpler than that for ideating and entry purposes.
The key is to allow anyone to add to it in a very easy fashion.
ex.
Potluck Ideas
* Mashed Potatoes (Idea by Alex Korxaras)
* Roasted Corn (Idea by John Doe)
* Wilted Spinach (Idea by Jane Doe)
Well, the solution I've mentioned is out of the box confluence functionality. For anything else than that, you have to search the marketplace.
