×Hi, We recently started using the Whiteboard and encountered an issue when working with Hebrew text.
When I type in Hebrew, the text initially appears as expected while I’m editing. However, once I click out of the text box for exit edit mode, the text disappears and is replaced with a blank square or box.
When I click back into the text to edit it again, the Hebrew characters reappear correctly
Hi @Gilad Barel Strul - yad2 ,
Seems like Hebrew is not supported in Whiteboards.
I can see you've already found an open feature suggestion related to this: CONFCLOUD-80755: Support Hebrew in Whiteboards
I'd suggest watching linked suggestion.
I'm not aware if there are any workarounds you could use :/
Tobi
