There seems to be an issue with the Confluence databases regarding the "Page Link" fields. Everything was working correctly until a few hours ago.
Given the table I have created, observing the visible fields:
If I access the content of the Page Link, it shows different data...
The field's configuration:
Could this possibly be a system bug?
It has always worked correctly in the past.
Thank you and best regards,
Hey @Miguel Monzó Montes ,
Is this still an issue? I quickly scanned JAC but didn't find the problem you're referring to.
If you're still experiencing the problem, I suggest reaching out to Atlassian Support for them to have a closer look. If it worked fine before, it might be that this was caused by some backend changes, but developers would need to check this out.
Tobi
I imagine it might be an issue with the update that took place on the 8th. I’ll try to resolve it, and if I’m unable to or if it happens again, I’ll report it to Atlassian Support.
Thanks for your response.
Take care!
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
