Issues Transitioning from Comala Metadata to Metadata for Confluence Plugin
Prudhvi Raju Kanithi June 21, 2024
Hi everyone,
We recently transitioned from the Comala Metadata plugin to the Metadata for Confluence plugin to save on costs. Our licensing team assured us that the new plugin would be a like-for-like match and that it would work automatically with our existing Confluence pages once the Comala Metadata plugin expired. However, this has not been the case. Even after manually adding the new metadata macro to our Confluence pages, I’ve noticed that the fields in Metadata for Confluence are not the same as those in Comala Metadata. Can anyone explain if both plugins serve the same purpose and if there are any steps we can take to ensure a smooth transition?
Specifically, I’m looking for:
1. Confirmation on whether Metadata for Confluence can fully replace Comala Metadata.
2. Guidance on how to properly migrate existing metadata fields.
3. Any tips or best practices for managing this transition.
Thank you for your help!
Lorenzo Manfredini
June 21, 2024 edited
HI @Prudhvi Raju Kanithi ,
I have seen that meanwhile, you opened a ticket with our Support.
I will take care of it ASAP.
I use this post to wish you a nice weekend.
Edit: sorry, I have to correct myself. You did not open a request. Please open a ticket using our Support Portal.
Best regards,
Lorenzo
Communardo Support
Nicolas Grossi
Banned
June 21, 2024
@Prudhvi Raju Kanithi You might want to contact the plug in provider: https://marketplace.atlassian.com/vendors/95/communardo-products-gmbh
HTH
Nicolas
SERVER
VERSION
7.19.16
