Sign up Log in
It's so hard to place multple images properly without going insane! Anyone know any tips or plugins?
carolinefangel
August 2, 2022
Anyone has any good plugins? I feel like I tried every relevant app on the marketplace, but none fix my issue, they're mostly image editors.
I can't believe images are always being down prioritized on these types of apps. Is it really that complicated to add a good gallery option?
The problem is that images in a text editor always jumps around like crazy, and it's really hard to guess how to put it in the spot you want it.
Please tell me somebody found a solution, I'll be so grateful!
Lucas Modzelewski _Lumo_
I always 'secure' place after image / macro etc.
some text before
<place for image>
a (just a placeholder - to know when the image ends
I also use soft enter "shift + enter" eg in lists, however as in the example above before adding image, I make sure I get the next item/number ^^
Here is example from one of our apps docs, with ordered list and multiple images:
https://psc-software.atlassian.net/wiki/spaces/ECSD365/pages/962920449/Getting+started
'Soft enter' is the key!
