Hi, hope everyone doing well.
For the JIRA Issue/Filter macro in Confluence, I currently don't see an option to reposition the columns to display by drag-n-drop so if I want a specific ordering for my columns in the table I have to remove and add them all over again. Is it by design? If yes, then it is not so efficient I would say. Is there a way I can put it as a feature request?
I found this one last week Rick, may be you can upvote too like I did :)
You can login on https://support.atlassian.com/ then select confluence>>Suggestions & Bug report>>Click on Create>>Select Bug or Feature request and Submit.
The Atlassian System Dashboard bookmarked https://jira.atlassian.com/secure/Dashboard.jspa has links to bugs & suggestions for all their products. Find the Confluence row then click the Suggestions column in the Cloud Edition section to search for an existing RFE to upvote it, if there isn't one then that's where you can submit a new one.
I always found this an annoying design where if I have six columns and want to add another one in the second position I have to basically rebuild the entire list of columns from scratch.
Thanks for your response Manoj, it isn't really intuitive in that case :(
I will keep the thread open in case someone can point me to where I can submit this as a feature request for future consideration.
Hi @Troy ,
It is by Design. If you want to re-order them then you have to re-add the fields again.
Not Sure about feature request if it is already created by someone or not.
Learn more
