JIRA issue count display from Macro
Sunil Kirangi September 13, 2021
Hi All,
I have similar query in my project but i would like to render multiple JIRA filter issues counts in my defect table.
I can able to get the query results from JIRA but its not customizable like only the number of issues instead it will display as 2 issues (hyper links) rathar than i want to use as only number 2, like below,
By click on each number i can view the issues list from JIRA.
I know this is possible to implement but the problem which type of Macros i need to and is there any pointers available for such kind of customization.
It would be really helpful if you share this information.
4 votes
Kishan Sharma
Hi @Sunil Kirangi
I'll recommend Table Filter and Charts for Confluence app to work with Jira Issues macro. By using pivot tables you can easily perform Count and Sum operations.
Katerina Kovriga _Stiltsoft_
September 13, 2021
Hi @Sunil Kirangi ,
I'm Katerina from the Stiltsoft team - Table Filter and Charts for Confluence is our app.
The addon indeed works with the Jira Issues macro perfectly well and allows you to aggregate and visualize your Jira projects - you'll be able to create dynamic Jira dashboards right in Confluence.
Maybe you'll be interested in a live demo from our team - please book your time slot here and we'll be happy to show you even more use cases.
Like • 2 people like this
Sunil Kirangi September 14, 2021
Thank you Kishan for swift reply and i will try this option for to display the count of tickets in my Wikipage
See inside
