JIRA issue/filter macro
kA
Hi Friends,
I have created the task in JIRA by using JIRA issue macro through confluence. By default it is display the key,summary and status. like,Is it possible to display the custom field value.
Thanks in advance,
Karthik A.
Tiago Comasseto
September 24, 2014
Hi Karthik, you can include additional custom fields editing the issue macro and selecting Display options, then at Columns to Display you can include JIRA custom fields.
I hope it helps.
Cheers
kA
Hi Tiago,
1.The "Display options" is enabled in search mode alone and for single issue the "Column to display" is not enabled.
2.  If I select the "Create New Issue" option it will display the system field only.
After I created the task it just display the Key, Summary and Status alone so I need to display custom field values too in confluence page regarding to the task through "Create New Issue" option. Is it possible.
Karthik A.
Tiago Comasseto
September 25, 2014
Hi Karthik, select Table, instead of Single issue at Display as options. It should allow you to edit the Columns to display list.
Cheers
Register now
