Hello, I'm able to select Jira issues by project or Lables but I'm not able to filter issues by Epic Link. It is possible? Thanks a lot in advance.
Hi Peter,
Have you try to use the "epic link" field?
e.g: Retrieve all issues under Jupiter epic
"epic link" = Jupiter
... or if you are on a next-gen project use parent instead:
parent = EPIC-
1234
References:
Regards
Hello, it's just not working. As soon as I add epic link into the query, I'm getting no result.
Have you try to perform the query first on Jira?
Please try also "Epic Link" instead of "epic link" or event "parent" if your project is a next-gen
If none of this work, please share with us a screen of Jira issue and their relation with the Epic to see if it is correctly setup or even if its linked using other issue link different to the Epic Link field
Regards
Hello again,
I don't know where to use this query directly in Jira.
Anyway, nothing is working:
"Epic Link"
Epic Link
"epic link"
epic link
also in combination with
"Schedule Optimization"
"schedule optimization"
Sample of issue linked to Epic.
https://files.fm/thumb_show.php?i=krp72tak&view
Thanks in advance.
Thanks, using Advanced searching you should be able to type the following query:
"Epic Link" = "Schedule Optimzation"
Regards
Perfect, everything works now thank!
Btw. Did you change/set anything or Am I stupid? :)
P.
Omg, now I see it, we have a typo in epic link name ... Completely sorry for all this thread :(
Hmm I've not edited any of my previous messages.
So probably you made a typo on your first try
Regards
still very helpfull, thanks @Jack Nolddor _Sweet Bananas_ !!!
Have the same issue, not able to filter via epic link, since my project is managed by the equipment, and the Epic Incidences have not Epic Name field
Help us plant more trees
