JSON syntax highlighting in confluence code block
Khun Ivan
April 15, 2016
How i can make JSON syntax highlighting in confluence in code block?
Nar Kumar C. - Narva Software
There is custom code syntax highlighter for Confluence Cloud https://marketplace.atlassian.com/apps/1219685/code-syntax-highlighter
It supports more than 300 programming languages and text formats including JSON.
Note: I am add-on developer.
Robert Massaioli _Atlassian_
April 17, 2016
Sounds like what you need is a Better Code Macro for Confluence Cloud: https://cloud-code-macro.atlassian.io/redirect/install
I wrote this add-on and I think it's pretty cool! Let me know what you think.
William Carr
August 26, 2016
It is pretty cool but the preview does not work. I'm able to add "better code block" macros but when I hit preview in my Confluence document I briefly see a waiting gear where the better code block macros are but then I see nothing in the place where the waiting gears were. If I hit save I see the code blocks rendered as expected.
August 28, 2016
Munish Desai
January 25, 2017
Can this macro be installed on Confluence server?
Also, it seems that the default code macro doesn't display the color highlighting when used in Questions.  Why would this be?  Isn't it the same code macro in both the page editor and Questions editor?
How does one make a new macro appear in the macro browser when trying to insert code in Questions?  Only the default code macro appears.
January 28, 2017
This add-on is only available for Atlassian Cloud. Sorry.
In questions you should be able to start with the { character to load macros.
Robert Galovic
I wrote a brush for JSON for the code macro - see here (just c&p):
https://community.atlassian.com/t5/Confluence-questions/how-to-highlight-JSON/qaq-p/285735
Mayur Jain
December 6, 2018
Marcel Nick July 14, 2017
We have developed a Confluence  macro  which provides syntax highlighting for JSON Objects .
