Jira Legacy Issue/Filter Macro
Trixie Johnson September 24, 2025
Will the Jira Legacy Macro continue to work after January 2026? It seems to work fine with new pages that use the Cloud Editor (vs. Legacy Editor).
Please advise!
Valerie Knapp
Hi @Trixie Johnson , thanks for your post.
I can't find anything that says the Jira Legacy Issue / Filter Macro is being deprecated.
https://support.atlassian.com/confluence-cloud/docs/learn-which-macros-are-being-removed/
https://community.atlassian.com/forums/Confluence-articles/Deprecating-infrequently-used-macros-in-Confluence-Cloud/ba-p/2981360
Why do you think it might be?
Cheers
Trixie Johnson September 25, 2025
@Valerie Knapp I am just trying to avoid an unexpected surprise!
I wanted to make sure I wasn't missing anything. It 'feels like' I am OK continuing to use this Jira macro, with the new editor.
Marc - Devoteam
September 25, 2025
Hi @Trixie Johnson
I agee with @Valerie Knapp .
But to be sure and not have to change any page where you use this macro, I suggest you start using the new macro.
Like Valerie Knapp likes this
