Jira Roadmap
Stephan Bertschinger
February 11, 2019
Hi There
i would like to integrate my Roadmap from Jira into confluence.
i know how to integrate the macro Jira-Roadmap and i can choose my project from Jira but it does not show anything..
Thanks for your help
Diego
February 12, 2019
Hello there Stephan! This behaviour could be caused by permissions or even the existence or not of an user.
There are some things you could check:
  1. Is the user you are using also present in Jira?
  2. Is any other user able to see the board content within Confluence?
  3. Is there any kind of restrictions set for the filter set within the Macro?
  4. Has this worked at some point in the past?
Also, could you clarify a few things:
  1. Do you see any kind of error when the Roadmap Macro loads?
  2. Does the macro finishes loading?
  3. Are you able to insert other projects in the Roadmap Macro?
  4. When did you first notice this behaviour?
Let us know Stephan!
