When accessing Jira and using the Project Pages option, the workspace or page not found alert appears. When I try to connect, the pages are shown, but when I try to connect the workspace, “Connection Failed” appears. If I access the Confluence URL directly, it works normally.
@Adriana there is currently an active incident that Atlassian is working on. They are are having issues linking Confluence Spaces to Jira projects. Follow the progress here:
Hi @Adriana and welcome to the Community
If you click that 9 dot icon in the top left corner of your Jira UI, do you see the desired Confluence among the Confluence sites available within your Org?
(I assume that permissions are sorted out since you're an admin)
