Macro not loading until page is published/updated
Asier Vadillo
Hi everyone,
I have installed a plugin called Easy Toolkit for Confluence that gives the option to create dropdown menus in Confluence. The main problem is that the macro/menu does not load while the page is in edit mode.
Once the page is published this pop up appears:
And the menus load, after that even if we enter edit mode the menus will be loaded and visible (Only the old ones, if we add new ones the same will happen).
If anyone has some insight in this topic let me know.
Thanks beforehand!
Marc - Devoteam
September 19, 2025
Hi @Asier Vadillo
This seems to be an issue with the app, as the macro is from a 3rd party vendor.
Reach out to the vendor and explain your issue, most vendors are responsive and keen on issues discovered and see if they can resolve them.
Tinker Fadoua
I agree with @Marc - Devoteam you need to reach out to the App vendor.
Best of luck!
Fadoua
