Is there a way in Confluence 5.10 to make body of disabled/absent macros visible in page view?
I'm interested in some another way than Tools/View Storage Format or writing user macros for unknown ones.
Is there some built-in plugin component to disable or Velocity template to modify?
Hi Oleksiy,
I don't fully understand - what do you mean by 'absent' or 'disabled'? And which problem are you trying to solve, i.e. why doesn't 'view storage format' cut it for you?
Cheers
Claudio
