×Hi,
I want to use the Timeline to plan work using using Epics and child-level issues (company-manage project). However, I can only see Epics in the Timeline, but not child issues.
Child Level Issue Scheduling is enabled in the settings and start and due date fields are also available at Epic and child level.
Is there something else I am missing?
Hi @Nuria Gutiérrez,
From the screenshots, it seems you are in a software project. Could you check 2 things:
Hope this helps!
Hi Walter,
To make the other issue types visible in the overall timeline you cannot exclude them in your board's filter. Just to satisfy my curiosity, could you please share what your board filter looks like?
project = NPIB AND issuetype in (Epic, Triage) AND "Physical Product Category[Dropdown]" = Consumer AND (labels is empty or labels != Taxonomy) ORDER BY cf[13821] ASC
Thanks. so any issue with any one or more of the following will be excluded from the timeline: issuetype other than Epic or Triage, "Physical Product Category[Dropdown]" other than Consumer, labels = Taxonomy. If any of those conditions are true the issue won't be included. Is that what you want? If not, I suggest starting with simply project = NPIB and then based on the results isolate any issue that you want to exclude based on the specific parameters and incorporate those parameters in your filter such that only those issues or excluded.
Thanks Jack, that's what I did and it now works perfect!
I have one last question. I have created a new board from a new filter with all the child issue types I wanted to include. When filtering by child issues, I can still see both Epics and child issues. Is there a way to have make visible only the child issue type that I select, removing the Epics from the view?
To the best of my knowledge, no you cannot exclude the epic component from the timeline view. Unsure why that would be desirable.
Can you go to the sliding bar icon on the right and at top of timeline then click on expand all Epic issues? Also, I assume there are indeed child issues under the epics?
Hi, yes, there are child issues within these Epics ( I posted a second message with a screenshot)
When clicking on Expand all Epics issues (or collapse) nothing happens
Hmmmm, let me ping others as I have never experienced this and TBH, I don't play with timeline much.
Just to keep things accurate in the Community I am un-accepting my a John's answers as it seems Walter hit on the correct answer.
Hi Nuria,
Are you using a Jira Work Management project? Because if you are, you can't see the proper breakout for Sub-tasks in a project Timeline.
The image below shows that it's a software project.
Yes, t is a software project, does this mean child-issue level view is not available?
I'm having a very similar experience --- My epics have child issues but they do not show.
HOWEVER --- if i use the '+' sign ON the timeline board to add a child task those tasks show up without any problem (they use the same issue type as the existing ones that don't)
