Multi Select Field Needs to APply filter on another Filed
Rayman Bacchus
March 8, 2024 edited
Hi All - hoping you can assist
I have a multi-select field where users can choose options  01 - 06 called ProductGroup
I want to use ProductGroup to apply a filter on a field called BusinessCapability
I currently have 2 rules sent up
if ProductGroup:01 then apply filter to BusinessCapability showing option 1,3,4,6,7,9
if ProductGroup:02 then apply filter to Business Capability showing option 1,3,5,8,12
The issue is if I multiselect ProductGroups 01 and 02 together only the BusinessCapability options 3,5,9,12 are showing.
So I want to select ProductGroups 01 and 02
and the filter on BusinessCapability to show options 1,3,4,5,6,7,8,9,12
How would I go about doing this?  Is it even possible?
Asha Goyal
March 9, 2024
Hello @Rayman Bacchus
Are you using Scriptrunner? As this is something that can be done with the help of scripting.
Regards
Asha
Rayman Bacchus
March 9, 2024 edited
No I don't use scripts.  I'm not en expert coder so I would have no idea how to implement or run such a script.
But am willing to take guidance if someone shows me how and it is the optimal solution.
I should also mention my companies version is Confluence is very limited and am stuck with what may be best considered Out of Box solutioning so ScriptRunner is not an option
