Does Opsgenie support multi-tenancy?
Organisation A and Organisation B under a main organisation to isolate alert management for different teams.
OpsGenie does not natively support multi-tenancy in the sense that organizations A and B would have entirely separate and isolated alert management systems under a single main organization, with no sharing or overlap between them.
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
@Humashankar VJ Is there are way to isolate alert management for different teams under a single license? Parent company with multiple locations or offices?
For sure, isolated alert management for different teams under a single license using workspaces is possible.
Regards
@Humashankar VJ I don't seem to find any docs on from Opsgenie docs, can you kindly share any reference for creating workspaces?
Opsgenie resources | Opsgenie | Atlassian Support
I believe you are already with an account with the help of this navigation - Opsgenie - What is Opsgenie? | Atlassian
Kindly reach out support for specific data points - Atlassian Support,
As your use case is quite unique out of it the team may come up with help guide in the near term.
Regards
