Need help with a script to find and replace text in multiple confluence pages
Jagadeesh September 17, 2021
I have been assigned a task to find and replace few words in confluence pages and I came across script runner as a very useful tool. I will be very thankful if anyone in this group can help me with a script that will help me to accomplish my task of finding and replacing text at the page level in confluence.
Thanks in advance,
M J
Kishan Sharma
September 18, 2021
Hi @Jagadeesh Welcome to the Atlassian Community!
This blog on scriptrunner site already have a script that you can download and modify as per your requirement. The example script works on a single space, but you can modify the code to loop through all your confluence spaces and its pages and perform search/replace as per your use case.
Jagadeesh September 20, 2021
Hi Kishan,
Thank you very much for your quick reply. Yes, I am using the sample script shared by the Script runner trial version tool, but it is throwing errors and I need someone who has already used this script to help me in debugging or modifying the current script.
The sample script shows how to modify within a table in confluence page, I want to modify text within a page in confluence. I am not sure what code elements to use. if you have an idea how to modify the script, please do message me at this mail id
jmadineni@billtrust.com. I will be very thankful for helping me out.
M Jags
Kishan Sharma
September 20, 2021
Hi Jagadeesh,
I will also suggest posting this question to Atlassian Developer Community so that you will get better solutions from the developers working on such scripting activities. I will also post here in case I able to get this to work.
Jagadeesh September 21, 2021
Hi Kishan,
Thanks for the suggestion. Sure, I will post in the developer community too. I have another 10 days before the trial version expires. In the meanwhile, if you know any groovy script developers please suggest their mail ids. I will try connecting with them.
Kieran Gainer
September 4, 2023
Hey, I just publicized a Node.Js script I created and have been using for bulk replacing text within a Confluence Cloud space.
There are two .js scripts included, one for swapping page content (index.js), and one for updating page titles (updatePageTitles.js).
Hopefully this helps someone!
https://github.com/krgainer/confluence-bulk-change
Kishan Sharma
September 5, 2023
Welcome to the Atlassian Community and thank you for sharing the script @Kieran Gainer !
Tiffany Wortham
March 8, 2022
Hi Jagadeesh,
Here's what your script might look like if you wanted to find and replace text anywhere on particular Confluence pages:
import com.atlassian.confluence.pages.PageManager
import com.atlassian.confluence.spaces.SpaceManager
import com.atlassian.sal.api.component.ComponentLocator
import org.jsoup.Jsoup
def pageManager = ComponentLocator.getComponent(PageManager)
def spaceManager = ComponentLocator.getComponent(SpaceManager)
def targetSpace = spaceManager.getSpace("SAL")
pageManager.getPages(targetSpace, true).each { page ->
log.debug "Inspecting page ${page.title}"
def body = page.bodyContent.body
body = body.replace('Human Resources', 'HR')
pageManager.saveNewVersion(page) { pageObject ->
pageObject.setBodyAsString(body)
Cami
Hello
@Tiffany Wortham Is this possible with script runner for cloud?
Tiffany Wortham
November 30, 2022
Hi cami!
I'm sure this is possible with ScriptRunner for Confluence Cloud, but your script will look pretty different because you'll have to use the Confluence Cloud Rest API.
Cami
Hey Tiffany. The Confluence Cloud REST API documentation states that connect apps cannot access the rest resource necessary to perform that action. Isn't ScriptRunner a connect app?
Like Brian Wilson likes this
