Need help
Touka Kirishima September 13, 2025
I cant login to confluence
Matteo Vecchiato
Hi @Touka Kirishima
To let the community help you, you should give more detail about the problem, like error, if you are admin, if company user or personal user and so on.
The following articles should help:
https://support.atlassian.com/confluence-cloud/docs/change-your-confluence-password/
https://support.atlassian.com/atlassian-account/docs/password-reset-issues/
I hope it helps
Regards
FREE
