×I'm no more able to reach Conflunce / Jira pages from my laptop while connecting from my home network.
The returned error is ERR_CONNECTION_TIMED_OUT - This site can't be reached.
If I switch on my phone connection it works fine.
Please help in solving the issue .
It seems there is an issue from a specific European ISP:
Hello there,
I have some members of my team that since yesterday can't access to our Confluence space.
They all have the same issue "the page is taking too much to load".They all work from home (different locations in Italy)
Already asked to clear cache and cookies or trying from different browser but it's not solving it. Odd thing is that for some members there is no issue (me personally I don't have problems).
Hello @Stefano Locati this is the same issue that @Pietro Nanni is having. As you are the second user that is being affected with this issue.
This was the incident that Atlassian had on August 22nd. Since all of the troubleshooting was done from the side of the community, you should raise a ticket for Atlassian: https://support.atlassian.com/contact/
Hello @Pietro Nanni
From your home network, do any of the other sites work? Is this only affecting Confluence or all of the Atlassian products? Also in your developer console do you get the 500 or 400 error codes?
Hello @Nikola Perisic , all the other sites work fine. I'm using Confluence and Jira and both have the same behavior .
I'm receiving the Canceled status code, so I think it could be a 444 .
For connecting to your Atlassian instances, do you have an identity provider set up, like Okta for example?
No, I'm using atlassian confluence / Jira on cloud, so I'm using the authentication from Atlassian
Do you have any proxy servers set up? Are you using a VPN?
No VPN and no proxy servers. If I swith the network from my home network to the telephone network, it works with the same configuration. I guess is something related to my network but I don't know what to check.
With your home network,can you ping atlassian.com using CMD/terminal?
Yes, I can:
Microsoft Windows [Version 10.0.22631.4037]
(c) Microsoft Corporation. All rights reserved.
C:\Users\pnann>ping atlassian.com
Pinging atlassian.com [3.160.212.13] with 32 bytes of data:
Reply from 3.160.212.13: bytes=32 time=61ms TTL=248
Reply from 3.160.212.13: bytes=32 time=41ms TTL=248
Reply from 3.160.212.13: bytes=32 time=15ms TTL=248
Reply from 3.160.212.13: bytes=32 time=14ms TTL=248
Ping statistics for 3.160.212.13:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 61ms, Average = 32ms
Something is for sure related with your home network. There might be a firewall rule set up that is blocking you to access Jira/Confluence
Hi @Pietro Nanni welcome to the Atlassian Community!
Are you able to share the URL of your cloud site? Just to test if it's reachable for other users. This might be a local issue then and not related to the availability of the site itself.
Hi @Dave Mathijs , the site is reachable by my colleagues and also by me when connecting through telephone. The issue seams to exists only from my laptop when connecting with my home network, so I think it is releted to something on my connection , maybe the IP ? But I don't know what to check
Then you'll need to contact your local IT support. This is not related to Atlassian.
IP allowlisting could be the reason, but you indicated that you're on a Standard product plan.
Below answers to your questions:
I confirm we are on a standard product plan
