I am no more able to add Children Display macro in my confluence page. Does anybody face same issue? Please suggest.
Surprisingly, it's just came back. I can see now. Not sure about what was the issue.
Basically, I'm not able to add children display macro anymore. Please find the attached screenshot for the result I'm getting while searching for the same. Is it removed from the default macro or something else?
Hi @Dhaval Khairnar ,
I don’t have any problem with it.
What exactly is not working for you?
Thank you.
