Not visible font
Hyunmin Kim August 1, 2018 edited
Hello!
I made an report for jira in confluence.
but it is not visible. (e.g SQUARE BOX)
How can I solve this issue ? Is it related to Korean font?
Lava Kumar Dukanam {Appfire}
August 29, 2018
Hi there,
Can you check if you have Encoding to be UTF-8 in the confluence configuration?
Though that's the default one. Just want to make sure if that's changed.
Lava
Hyunmin Kim January 7, 2019
Ok. I'll try it. Thank you for your comment.
