Hi @Chris X
I recommend looking at Space Sync for Confluence by Ricksoft.
In your setup - Master -> 2 Dupes, you have three options
No need to duplicate, copy, or anything like that, just sync the the content.
The app is extremely flexible and customizable - including permissions, so you can determine who can sync pages individually per space.
Crucial feature of the app is that it also converts links - Master Page 1 link to Master Page 2 will become Dupe Page 1 link to Dupe Page 1, etc. (Just make sure to use inline links).
Disclaimer: I'm not affiliated with Rickosft, I just use their apps.
Maybe you can approach the problem in a different way:
In order to allow different people to edit different parts of a document, consider splitting the document into multiple parts and using the include macro ( https://support.atlassian.com/confluence-cloud/docs/insert-the-include-page-macro/ ).
Good tips - thanks.
Yes - Dupe1 can replace Master once Dupe1 is complete.
However any version history would then be lost from the ‘Master’ as Dupe1 would then be the “master”.
Then still have the Dupe2 issue.
Both people might need to make updates to the SAME section. Good to hear about this feature though so thanks.
Your advice is appreciated.
