Point Confluence to SharePoint
Lou Pereira August 31, 2021
Hello, I would like to use SharePoint as a standard for documentation repository?
Can someone provide details to connect these two.
Kishan Sharma
Hi @Lou Pereira Welcome to Atlassian Community!
You can explore below third party plugin for integrating confluence with sharepoint -
 SharePoint Connector for Confluence
A_ Boehme
Thank you @Kishan Sharma for pointing to our app!
@Lou Pereira The SharePoint Connector is indeed a helpful solution to display SharePoint documents and lists in Confluence as well as Confluence content in SharePoint.
You will find our documentation here and feel free to contact support any time.
Feel free to test it out with a free trial and let us know, if you have any questions!
Best
Almuth
Communardo Support
Like # people like this
Lou Pereira September 1, 2021
Thank you for your reply, but this sounds complicated?  I'm not looking to add complexity to the environment.
Kishan Sharma
It all depends on your requirements. You can keep both these systems separate and just add links to one another (eg: add document link from sharepoint to confluence page or vice versa) if you don't want to invest in a plugin.
A_ Boehme
@Lou PereiraWe put a lot of thought in making the SharePoint Connector easy to install and to use. But @Kishan Sharma is right, in the end it depends on your requirements.
If a look around the app would be helpful to you to get a better idea of what the SharePoint Connector does our product team would be happy to chat with you.
In that case you can use the following Microsoft Bookings link to directly schedule a meeting with our experts: Book appointment here
If you'd like to go in a different direction, don't worry. I'm sure this community will find something helpful if you share a little more about your requirements.
Have a great day!
Almuth
Communardo Support
Lou Pereira September 2, 2021
Thank you.  Yes I have a call to further understand and see if it fits my goals and budget.
We are a start-up and do not have unlimited funds as other established companies.
Like A_ Boehme likes this
