Problem with Confluence and very large number of (>200) drawio images
Madhav Gudimetla V
Hi Team,
I have written a confluence document for a product user guide for my company, which has more than 200 images rendered using the drawio plugin.
At the time of writing up the confluence page, I was able to add and publish many drawio images.
For some reason, in the past 2 days:
  • the confluence page doesn't seem to load all images
    • Takes ages to load images
    • Am on 200Mbps internet connection speed
  • the edit icon of drawio on mouse hover in the published page doesn't always appear
  • editing the confluence page and selecting the edit of drawio image leads to a different problem
    • unable to export the image
    • unable to select all objects and copy/paste to another drawio space  (outside of confluence space!)
    • unable to close or publish the edited drawio image
I tried on Chrome and Firefox browsers. The behavior is the same.
However, I tried using Safari, and the behavior is different.
  • Able to select all drawio objects in edit mode
  • Able to copy drawio objects, and paste to another drawio space (outside of confluence space!)
  • Able to publish and close the drawio image
  • However, the problem still persists in safari
    • unable to export drawio image to .png or .jpg format
Problems to summarise:
  • A very large number of drawio images (say > 200) on the confluence page do not load fully
    • Drawio plugin throws an error "there seems to be a problem loading the page or something"
  • Edit icon on drawio image in a published confluence page doesn't appear
  • Unable to export confluence page to .doc with a large number of drawio to .doc
    • but able to export to .pdf (which is undesired for me) using Chrome, Safari, and Firefox browsers
  • Behaviour is different across - Chrome, Firefox, Safari - when working with confluence + very large number of drawio images
  • Unable to select all/copy/edit/to publish/close drawio images (in Chrome and Firefox browsers, but NOT in Safari browser!)
  • Clearing cache in browsers did not help
    • The chrome browser version is "Version 85.0.4183.102 (Official Build) (64-bit)"
    • Firefox browser version is "80.0.1 (64-bit)"
    • Safari Browser version is "Version 14.0 (14610.1.28.1.9)"
This is preventing me from publishing my work to my customer - highly annoying!
I need a fix for this ASAP! Please help.
David Benson [draw.io]
October 4, 2020
Are you certain it's the draw.io app showing this message, could you paste a screenshot please?
Could you also post a screenshot of the draw.io section in the manage apps admin page expanded please? If you'd rather not post these details here, our technical support desk is at https://drawio.atlassian.net/servicedesk/customer/portal/14/group/15/create/49. Please include your SEN in the description.
Madhav Gudimetla V
Hi David,
Thanks for your response.
I did check over the weekend and found that drawio is showing the image correctly, with the edit pen icon on mouse hover over the image. None of the problems I posted above persist!
As a result, I am unable to capture the error message and post here or in the link you suggested.
Should the problem resurface, I shall post the screenshot and seek resolution.
I think I should close this ticket as its no longer occurring!
Sincerely,
