Hi all,
When creating a project via cloud is anyone aware of a way to request project approval in an automated fashion to senior management via email? If approved then it is moved into an approved section and if refused then this to move into a rejected section?
Thank you in advance!
Hi Jack,
For Confluence Server our App Easy Document Signer could be a solution to your requirement. You can find it on the Marketplace.
Stephan (CEO of EPS Software Engineering AG, the vendor of the Easy Document Signer)
Hi Jack,
Can you confirm if you're referring to Jira or Confluence? Your question is in the Confluence collection, but it doesn't appear to be related.
You mention approvals and projects, so can you confirm if this is actually for Jira? Can you clarify a bit what you mean by "project approval"?
Approvals do exist in Jira Service Desk but it's a per-request basis.
Shannon
Hi Shannon,
It's related to confluence. So I set a project plan on a page in Confluence but when I do I am able to request approval from senior management to approve the project plan.
Jack
Hi Jack,
Thank you for explaining your issue.
While there's no approval process in Confluence, there are various add-ons that could help with this.
Have a look here as well for more information:
Have a look and let us know if you have any questions about that.
Shannon
