This is about the external (guest) users where every guest gets access to only one space. If I put all guest users in one space - can I have multiple folders in that space and have each folder accessible to a subset of users?
For example let's say I have Guest-Space, and two guests g1 and g2. I wish to create folder1 and folder2 and grant access to folder1 to only g1 and folder2 only to g2. Is that possible?
Hi @Abhay Patil
I guess you can play with page restrictions - basically restricting sections/pages to specific users.
You may try creating 'subsets' of user groups from specific guests (and then restrict pages to those specific groups.
Or, you can create multiple spaces - G1 and G2 - then assign specific guests to specific spaces.
Thanks. I need to create only one space because I need a "folder" that both g1 and g2 access and also a folder only for g1, and another only for g2. I can't use spaces because a guest can have access to only one space.
And now I understand that I need to use pages as folders - as pages can have sub pages.
