Question on Markdown Exporter for Confluence
James Mak
July 12, 2023
Hi Team,
I am evaluating the plugin and trying to export my Confluence pages to Markdown pages. Plug-in used: https://marketplace.atlassian.com/apps/1221351/markdown-exporter-for-confluence?tab=support&hosting=cloud
I found that the converted pages are missing some text, some tables which appear in the original Confluence pages. And some converted tables are not displayed properly until I manually edited the table in Markdown format.
May I ask if there is any setting I missed during the export process?
James
Diego Zabala Betancur November 21, 2023
I'm getting a similar issue trying to export a Confluence space using the 'bulk export' feature. It does not crash but it's not downloading the whole data. The pictures into the excerpt macros didn't get downloaded and this is a big issue because some data is missing into the exports.
Does anyone know a way to adjust the settings of the app to get it working?
Nar Kumar C_ - Narva Software
Hi Diego,
I replied to your support request. This is indeed a bug when you use Excerpt Include to include images from other pages, as the images belong to the original page.
We will try to find a fix for this.
Nar
Like Diego Zabala Betancur likes this
thanks a lot!
Hi James,
I am part of the team behind this app. Please submit a support ticket with details from the link you posted: https://marketplace.atlassian.com/apps/1221351/markdown-exporter-for-confluence?tab=support&hosting=cloud
You can click on Submit a support request to raise a ticket and we are more than happy to look into the issue.
Andrii Maliuta
July 12, 2023
Hello @James Mak ,
It can be better to write directly to the vendor support to get answers . Contacts are on Contact/Support page.
