Hey all,
Does anyone know if it's possible to reduce the column size when creating a Jira table in Confluence?
For example, in excel, you can reduce the column width and make the text continue below (creating like another 'row'). Hopefully it makes sense.
Here's an image for reference:
Hi @Martina ,
If you use the Table Filter and Charts for Confluence app (our company develops this add-on), you may use its Table Transformer macro as a workaround: wrap your Jira Issues macro in the Table Transformer macro and follow this example from our documentation https://docs.stiltsoft.com/tfac/cloud/advanced-table-cells-formatting-58426218.html#Advancedtablecellsformatting-Changingcolumnwidth
Hi @Janice ,
Please add some tags for us:
Thank you!
